Noise and vibration when hubs are locked 2wd and 4wd
Old 01-28-2017, 03:25 AM
kazuya2416's Avatar
Originally Posted by Co_94_PU
That was me man I'm sorry if I discouraged you from posting questions or anything. My intend was to keep your debugging in one place, as was the case here things got lost and confused. It's perfectly acceptable to bump your threads also if you've gotten no response (use your judgement) to get fresh eyes on a problem, they tend to sink off the new posts lists and such.. again so sorry!
List your vehicle specs again, some have issues others will not specifically I'm vaguely recalling an issue with an ADD model with floppy bearings one one side. Others know those models much much better than I do.
copy that brother
Old 02-26-2018, 09:59 AM
22BrokeBoyRE's Avatar
Updating. Finally got around to greasing my spindle bushings and that solved my issue.
Old 02-26-2018, 02:19 PM
muddpigg's Avatar
Thanks for reporting back. Would be nice if it helped a newbie but they'll probably do like you did.
