Looking at truck bad clutch
So I am new here to YotaTech and I am looking at a 1987 Toyota pickup. It is pretty beat up but still runs like a champ except for the clutch is wearing out. I am new to driving manuals but I really want one. Should I keep looking have my mechanic look at it or try and get it fixed? I am on a high school student budget.
You said you're new to manuals. Are you sure it's just the clutch wearing out? What is it doing? How many miles, which engine and how much is the guy asking for it? It may not be the deal you're looking for. We can probably give you a little better advice with this info.
Staff
Clutch is only going to be part of the issue, there will be other problems. You are having the work done and that is going to get expensive quick. Around here a clutch job is $650-$750. Then I suggest changing the Master and Slave Cylinders. Not hard or expensive to do by yourself changing them but should be done. I would only suggest you buy it for a learning or project experience like wyoming mentioned. I see "Mechanic" and "Budget" in your post. You might want to pass.
Clutch is only going to be part of the issue, there will be other problems. You are having the work done and that is going to get expensive quick. Around here a clutch job is $650-$750. Then I suggest changing the Master and Slave Cylinders. Not hard or expensive to do by yourself changing them but should be done. I would only suggest you buy it for a learning or project experience like Wyoming mentioned. I see "Mechanic" and "Budget" in your post. You might want to pass.
It just depends on how much your willing to do yourself. I mean seriously. A good clutch is anywhere for 80-300 for parts. Throw in $100 for slave and master and the 40-60 for flywheel machining. You realistically can probably get the parts to install the clutch for under $350 but a shop is easily going to charge you a day to do it all. 99.9% of these old trucks no matter how nice of condition need at least a few hundred to a few thousand thrown at them just to catch up. 200+k miles with the factory timing chain then you looking at replacing that as well so there is another few hundred bucks. Then are you going to tare in to the head? Lower end?
If this is a project to you and you have a spare DD then this might be a good learning experience. Will your friend work for free and show you how? How good of a friend is he. I have a great friend that is a legit mechanic and shop owner and I still pay 20-30/hr if my rig goes in to his shop. But then he has to at a minimum pay his guys to work on it.
If your mechanically inclined you can do just about anything to these old trucks. If not then they can be expensive just like any other rig. If you are buying this for a turn key DD then maybe look at something newer with maintenance records. I know it's a lot more than this rig but I found my wife a 98 limited 4Runner 117,000 miles W/E-locker and all the maintenance records mostly dealership for $8800. And it's super clean. Pick a date up in your nice clean good condition rug clean. I saw them as low as 4 grand but they either had a salvaged title or stupid high miles. She wanted a turnkey DD so we paid a bit more but worth it in the long run.
Figure on that truck being a 240K mile truck for $2500 which is the least you'll have in it before it is dependable. Ask yourself, can I find something better for $2500 or something a lot better for $3500 and then make your decision. I like learning experience vehicles but I have never broken the $1000 mark on a vehicle that I knew was going to need a major component rebuilt or replaced. A full clutch job with no experience, I would count as a major component. Got any pictures or the rig? A picture is worth a thousand words. If it is super clean, it may be worth the trouble.
