how much lift do i have..?
hey guys, i recently imported my 93 Surf from japan, its definately got a suspension lift on it, but i dont know how much, i took some measurements and was hoping you guys would be able to tell?
its got:
-some sort of aftermarket springs in the rear, silver in colour..
-Rancho 9000XL shocks front and rear p/n:
-RS999145 front -- Collapsed 9.625" Extended 13.375" Travel 3.75"
-RS999208 rear -- Collapsed 14.000" Extended 22.5" Travel 8.500"
-adjustable track bar
-aftermarket torsion bars, says "Elford-TH01-L-XC" on it.. did a search and nothing came up with that?
-shortened bumpstops in the front
and i took some measurements from the center of the hub to the bottom edge of the fender above the wheels, and this is what i got:
21.5" front
22.5" rear
the truck was slightly tilted to one side cuz of the slant in my driveway... but i measured both sides and they were only .5" higher/lower than the other side.
heres a pic of my truck.
from looking at pics of other peoples rigs... would it happen to be a 2" lift on my truck? i was trying to find the lengths and travel of the stock shocks and maybe try to figure it out with that but couldnt find anything.
and lastly, i want to get another 2" of lift out of it with some rear coil and bj spacers, would i need to get longer shocks? or will the shocks i have on there now limit the travel?
i really like the rancho 9000xl's on there right now.. super nice ride!
its got:
21.5" front
22.5" rear
anyone kind enough to go outside and measure from the center of their hubs to the bottom of the fender on their truck (with a known amount of lift) for me so i can compare?
the tires are ~31"s but it shouldnt matter as im measuring from the center of the hub
yes, the thing on the fender is a mirror, factory on all the hilux surfs
thanks yoterr! but i think the 2nd gen trucks has a taller wheel arch in the fenders than the 2nd gen 4runner/surfs.. cuz according to my math using your measurments.. mine has a 1" DROP... haha.
im just gonna guess its a 2" lift.. so if i do another 2" lift with spacers, im gonna need longer shocks arent i?
Simple as.
Fred
Most measure (in the front) about 14" from the top of the rim lip to the bottom of the fender. As for the rear (same place to measure - from the top of the rear rim lip to the fender) is between 11" and 12" depending on sag.
Hopes this helps.
Larry
Hopes this helps.
Larry
Hi all Newbie here and just wanted to say Hi!! Nice truck by the way and looks like a 2/3" supsension lift and maybe 2" body lift? used to the kits from the UK though so may be wrong........
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
