After 2" lift the front sits way higher than rear
Update!
Put new springs on the back it raised it! However its still not as high as the front, but only about 1-1 1/2" difference. I had to put new rims on because the 33" tires were rubbing the upper a arm and a 1/4" spacer wouldn't do the trick. So there went more $ but im happy with the way it looks. The tires are a bit louder than i expected but perform well so far. Now time to deal with the cylinder 5 misfire after replacing sparkplugs, wires, and coil pack...$$$
Looks real good. Good luck with the misfire. I had one on cylinder 1 and all I did was change around the coil packs and regrease them and that took care of it (so far at least...)
Mud tires are definitely louder.
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
Vargntucson
07-04-2015 12:15 PM
