94 hilux miss
94 hilux miss
my 94 22r helux has a miss and I cant figure it out.... I have done timing carb plugs leeds valves compression test and replaced leeking manifold gasket...
please help me
please help me
Missing at idle or under load?
Did you check the condition of your distributor cap/rotor? Test ignition coil?
http://www.teamtoyota4x4.org/archivi...e/onvehicl.pdf
Take a look at all the grounds for your ignition as well. I had a similar problem and it was a corroded ground. I fixed the ground a couple of months ago, the gripe hasn't reappeared.
