1980 toyota 4x4 carb problem
Old 01-14-2012, 07:35 PM
tazzer's Avatar
1980 toyota 4x4 carb problem w/r22
Hello all, Im new to toyotas but I baught a farm last year and the land came with a bunch of equp. and the little truck. well I have just now had a chance to check it out and after putting a batt. on it and a little gas in the carb it fired right up. T he problem is it will not stay running, it burns the gas that I pour in it and then dies.
this is what iv done to this point.
1st Iv changed the filter, checked all lines dumped and added new gas in the tank and checked the fuel pump.
I get gas at the carb but it does not seem to be getting into the barrels.
the truck had sit for 3 years and a rat has chewed some of the wires into and im not sure if this may have something to do with the problem. thanks and sorry for the long post
oh and heres a pic of it
Old 01-14-2012, 07:37 PM
tazzer's Avatar
wires into
heres a few of the wires that were chewed into, that i dont know what they control
Old 01-19-2012, 08:25 AM
2Wheeler's Avatar
I'd repair the wiring first. Since we don't know what exactly it controls without doing some research on wiring schematics, it wouldn't hurt anything and it might help.
If the truck sat for 3 years not running, the fuel tank may need to be emptied of all the old, dead gas. Your tank may have a drain plug - if so then you won't have to remove the tank.
Then, check to see if you get fuel actually pumping when the engine is cranking. Disconnect the fuel line at the carb and have someone crank it while you hold the fuel line into a container. You should get gas flowing while cranking.
To check the carb, run a gravity-fed fuel system straight to the carb to see if it's working. This will bypass all the tank, filter, pump and lines to remove them from the equation. Just take a small gas can, insert a rubber fuel hose into it and plug the other end into the fuel inlet on the carb. Crank engine, and see what happens.
Old 01-19-2012, 08:39 AM
Sensei's Avatar
Sounds like your needle is stuck in it's seat, hence no fuel is flowing into the float bowl. Recommendation is do everything 2Wheeler said along with rebuilding the carb. Three years of sitting will surely gum up orifices, jets, air/fuel passages, etc.
You may have multiple issues that need top be corrected......
Old 01-19-2012, 07:08 PM
tazzer's Avatar
thanks guys, Its running now but has a problem with starting once its running I have no problems but once it dies I have to spray starter fluid or pour gas in the bbl.
Im thinking maybe a chock problem but the carb will proably need rebuilt just like yall said
Old 06-18-2012, 04:00 AM
tazzer's Avatar
update
Well I found a carb. on ebay for 60 bucks that came off a 82 pu that they upgraded to a weber. nothing wrong with it so I baught it. got it in cleaned it up and installed it.
then found that the pump had went bad also ran to parts store and picked one up for around 40 bucks.
got home installed it and shes running like a champ now have a few more things to do but shes up and going now.
Old 06-18-2012, 07:40 AM
82shorty's Avatar
Good to see you got it running. With a little TLC it looks like it will be a nice solid truck. Long live the first gens!!!!! More pics???
Old 06-18-2012, 11:54 AM
tazzer's Avatar
Ill post some more once I get her cleaned up a bit
Old 06-18-2012, 11:57 AM
tazzer's Avatar
shes only been sitting for about 5 years lol
changed out all the fluids, gas, plugs and wires, filter and replaced teh clutch sleeve, carb and fule pump. so for got around 175 to 200 in her and she came with the farm I baught two years ago Liked the little girl so much I went and baught a big brother to her lol
2001 tundra with only 52600 miles
bigblue82
10
07-06-2015 08:27 AM
Crazy_Guy97
12
06-24-2015 04:02 PM
Corey
24
07-15-2002 07:53 PM
Krash
10
07-13-2002 09:21 PM
Quick Reply: 1980 toyota 4x4 carb problem
