WTB[International]: 3rd gen clutch pedal arm
Hey like the title says looking for a 3rd gen 4runner clutch pedal arm don't really need the clutch pedal pad. My spring has worn a deep groove into my pedal and don't have access to a welder myself.
EDIT: Here's the thread I was looking for: https://www.yotatech.com/forums/f2/f...37/#post173777
OR you could try the spring mod....let me see if I can find you a link....
Some info in this thread...
https://www.yotatech.com/forums/f2/c...spring-283306/
That said, I replaced the clutch pedal and spring (your spring will be worn, too) 85,000 miles ago. Should it go bad again I will definitely be going the other route, that thing was a bear as was the stinky little plastic bushings.
EDIT: Here's the thread I was looking for: https://www.yotatech.com/forums/f2/fixed-st...37/#post173777
https://www.yotatech.com/forums/f2/clutch-pedal-spring-283306/
__________________
My rides:
'96 4Runner SR5 4x4, manual, e-locker, manual hubs too. Stuff happened to it. Stuff is still happening to it.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff.
Habanero's 96 4Runner build thread
My rides:
Depending on how the clutch acts, just adjusting the pedal might do wonders for the feel of it. My 96 Tacoma pedal I had to lift slightly with my foot to get cruise to work, but the clutch engaged right off the floor. Adjusted the pedal and no more problems, clutch felt tons better, and no more messing around pulling it up to get cruise to work.
Fixing the spring problem is never a bad idea, never ran into that personally yet, atleast not one bad enough to notice.
Sometimes it's more than a little adjustment...spring and clutch pedal eat each other over time....
The spring
The Clutch Pedal
Dunno if they're still available, but I got the replacements from Toyota.
The spring
The Clutch Pedal
Okay so i have become a believe of the linear spring mod! popped the big spring out and replaced with a brake return spring I got at an auto parts store. Only had to make minor adjustments to get the spring to have the "feel" that i prefer and bam, no more clutch squeak and having to kick it to the top.
Awesome!
