won't start
Old 10-29-2008, 09:09 AM
jetski0602's Avatar
won't start
Ok guys, new here. Did a head gasket on a 91 22re. I put her back together.. all wires connected, timing chain on, oil and coolant in.
I go to start it. It cranks but won't turn over....
no idea where to go from here.
No spark possibly, or could it be something I did while replacing the head gasket??
please help, trying to sell truck for a buddy just need her to start
Old 10-29-2008, 09:11 AM
Staff
DeathCougar's Avatar
Check your distributor, it may be 180 out. Thats the most common problem.
But start with the basics: Air, Fuel, Spark. Does it have these three elements?
Old 10-29-2008, 09:16 AM
jetski0602's Avatar
feed fuel. actually flooded w/ fuel.. has air, not sure how to check spark and how do i ensure the cap isn't 180?
jetski0602's Avatar
i never removed the cap. just pulled the dist as a whole
Old 10-29-2008, 09:19 AM
Staff
When you put the dist. back in, you should have set your engine to 0' BTDC, and the rotor in the dist should point to #1 in the cap. If you didn't set the dist timing, you need to pull it back out. Its almost impossible to install the dist without taking off the cap, to see where to rotor is pointing.
Old 10-29-2008, 09:23 AM
jetski0602's Avatar
ok so pull the cap set it to 0.. rotate crank to tdc and she might work?
Old 10-29-2008, 09:26 AM
jetski0602's Avatar
one more thing.. the first time we tried to start her.. she wanted to turn over.. but nothing but a pop on the intake side.. and a cloud of white smoke.. since this.. no more smoke.. could this also be a problem? where would it have come from?
Old 10-29-2008, 09:29 AM
Staff
The pop and smoke is from being out of time
Old 10-29-2008, 09:36 AM
muddpigg's Avatar
There is a ground that connects to the intake. It easily hides itself, comes out of the wiring the injector wires do.
Old 10-29-2008, 09:39 AM
Staff
Pull the dist, set the crank to 0, and reinstall the dist with the rotor pointing to #1. You have to make sure the engine is on the compression stroke (ie both valves closed) this can be done by taking off the valve cover, or just guessing. If you guess, and it still doesn't start, you just need to switch it 180
Old 10-29-2008, 09:58 AM
rockb1's Avatar
hey was your running rough?
Old 10-29-2008, 10:07 AM
jetski0602's Avatar
last time the engine ran.. it was rough as hell cause the oil and water mix.. havn't started it since
jetski0602's Avatar
in class now, but when i get out i'll play with the dist. and get back with you guys.. thanks for the help for now
Old 10-29-2008, 07:20 PM
jetski0602's Avatar
i'm back.. she runs thanks to deathcougar.. thanks again man.. it was the dist.
now she runs.. but really really rough.. a real high idle and jumppy. I need to adjust the lifters cause i tinkered w/ them when i put the new cam in.. but could this make it a high idle and jumppy??
or is my timing off?
but, she runs.. that's what matters no i must work out the fine tuned stuff
Old 10-30-2008, 10:41 PM
muddpigg's Avatar
Glad to hear you running.
Old 10-30-2008, 10:51 PM
abecedarian's Avatar
could be timing, could be valve adjustments
Old 11-01-2008, 06:58 AM
jetski0602's Avatar
it's vacuum and i can't figure it out.. i have all 10 or 12 diagrams but no idea which engine is the one i'm working on.. it's a 91 manual trans 22re fuel injected
sandyota
02-04-2021 11:16 AM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
karbin
07-05-2015 11:37 PM
Quick Reply: won't start
