Window track Install
Hello everyone...
I've got my new set of window tracks for the 94 SR5, and i'm having difficulty installing them.....
At first, i tried it with the door closed and the window halfway down, alighned with the arms, however the window will just not squeeze into the tracks.....
Is there an easier meathod to do this ??? i just can't get the leverage to seat the window in the tracks.
any help would be appreaciated. !!!!
Thanks !!!
Thanks !!!
Na, the window just doesn't guide into the tracks, it squeezes into them. I can alighn the window on the tracks, but getting them to fit in the rubber tracks with the inserts is pretty tight.
Does anyone have a better way of fitting the bottom of the window into the tracks??
Perhaps open the tail gate and install the window into the tracks/arms from the open position??
You should definitely be doing this with the glass out of the tailgate. Fold a thick blanket in half a few times to make a nice soft "cushion", put the top edge of the glass on the "cushion", lube up the glass and rubber insert with liquid dish soap (as slacker mentioned), then push it down onto the glass. It goes on tight, but the soap will really help. I used a rubber mallet and gently tapped them on (while the glass was resting on the blanket).
Second, assuming I get the guides on the glass, and through the opening (with molding out), how am I going to get the rollers on the end of the regulator arms into those tracks?
Okay, I got the inside molding piece off. Hope I can get it back on later.
I'm going to get the new tracks and rubbers mounted on the glass now. Then see if I can figure out how I'll get it all situated so that I can get the knobs on the regulators into the tracks. Hopefully I'll have a "Eureka!" moment.
I'm stumped. I know that the answer is right in front of me, but I don't see it.
How do I get this together -- the rollers at the end of the regulator arms into the tracks on the channel assembly? Pics:
I can't move the window side-to-side because it's in the side tracks. The rollers look to be permanently attached to the arms. So . . . ???
Thanks, slacker -- that did the trick! I had to unsnap some of the wiring clips, which were holding it back from moving side to side, but once I did that I got everything lined up perfectly. It's all back together, and working awesomely.
The liquid soap helped. But I did it a little differently than others, I think. I put the rubber pieces on the glass first, then used the soap to help me put the channel assembly over the rubber. I tried it the other way first, but there was no way I was going to get them on the glass already put together.
Thanks guys, without Yotateck I probably wouldn't have tried to do this myself in the first place. Feels really good to have fixed this myself.
terminator
07-27-2015 07:13 PM
britishdudes2dr
07-25-2015 06:47 AM
icentropy
07-14-2015 10:23 AM
