will a95 4runner 3.0L A/C fit into 2.2L 4runner?
a guy wanted to buy my A/c system today and he has a 2.2L 4cyl, i wanted to know if the unit and lines and all that stuff would fit?
thanks
thanks
Do you mean the person has the 22re engine?
Well, if so, then the interior related components should fit- evaporator, etc., as long as the years / body style are in the same range. The condenser should fit as well but I'm not familiar with where the compressor mounts to be able to say if the hoses would work or if the compressor would bolt in.
Deathcougar can prolly answer those.
At least I asked about the possibility there was a 22re involved instead of just assuming that since the OP said 2.2L he meant 2.2 (20r), and then I went into what may be interchangeable if the OP did make that mistake.
Help me understand here....
I have an 88 22re 4Runner. Is there a different condenser for my engine than the 3vze has? All my searching tells me there are two condensers- one is 'standard' and the other is 'super-cool'. Which one should I have?
And what is the difference?
sorry guys i meant to put 2.4L 22re
so everything but the lines should work, he will be here tomorrow and im going to take a look and see what we can do
thanks guys and sorry for the mistake
also how much do you think a good price for everything that involves the air conditioning?, theres 144K miles on it and i dont know if it was every replaced, if that matters
I would like to help you more, but like I said, I don't have experience with the v6 and the related differences with the 22re....
... and one of the few people I would recommend help you doesn't seem too interested.
I've priced aftermarket a/c kits for my 91 truck and they end up at around 1200-1600 installed so considering used parts, I'd probably half that price at least.
icentropy
07-09-2015 02:12 PM
