why wont you start????
i have a 1994 toyota truck with a 1995 22re motor. it made a pop and started running rough. i parked it for a long time and went to start it recently and had no luck. the timing checks out...it is getting spark...but it is NOT getting fuel. i ran a wire to fuel pump and it works but wont start like that either. i replaced the main efi relay and still no luck. any suggestions????
the popping noise could be from running lean, shagool22 is right about more details. check to see if there is fuel at the fuel rail and if injectors are firing also
ZONAYODA
07-13-2015 07:17 PM
Poncho0206
07-10-2015 06:21 PM
