Why is my cat sideways, and what is this button to
Im pretty sure it suppose to be flat up against the body
and what is this button, its on the bottom of my driver side dash, by my right knee
Your cat should be flat, but will work just fine the way it is, it was probably removed or possibly replaced and not put in flat for some reason, as for the button, no idea what its for, its not a stock button so you will need to follow the wires and see were it goes.
Location: spokane, wa (then), mesa, az(then) Eugene, OR(now)
The button is probably for your alarm system overide. It's a means of turning off your alarm after your key is in the ignition. It's usually preset so that you have to push it a specific # of times to cancel the alarm. All of this assuming you have an alarm, usually aftermarket. That's my guess anyways.
gyroscope7
7
09-27-2015 08:39 PM
