Where's the Fuel Filter? '89 4runner V6
Old 05-21-2010, 06:14 AM
wrenchtech's Avatar
It's raining outside and she's parked in the mud. I can't see anything from on high. Would be cool if t was on the frame and not hidden under the manifold. -- Matt
PS It's my first 3vze powered vehicle.
Old 05-21-2010, 07:30 AM
yayfortrees's Avatar
Time to get that manual downloaded!
Old 05-21-2010, 08:48 AM
aa1911's Avatar
not sure if it's the same spot as i have a 93 runner but same engine; look under the driverside on the inside of the frame about where the front door hinge is...
Old 05-21-2010, 09:34 AM
flecker's Avatar
Location: White Mountains, Arizona (Yes it does snow in AZ)
On my 89 it's on the passenger side frame rail. Look on the inside frame rail around or just behind the door...
Old 05-21-2010, 10:02 AM
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Pass. side, inside the frame rail right near the tranny crossmember?
Old 05-21-2010, 10:39 AM
OutlawMike's Avatar
Passenger side, inside of the frame rail, right behind the front torsion bar mount point, were the adjuster is for the torsion bar.
Old 05-21-2010, 12:40 PM
wrenchtech's Avatar
Thanks everybody. You have given me what I hope is good news (that it's not buried under the manifold). BTW I have Toyota factory manuals for both the 4runner and truck for '89. I didn't see anything on the fuel filter in there. -- Matt
Old 05-24-2010, 06:54 PM
aa1911's Avatar
yeah, toyota doesn't recommend ever changing the fuel filter but seems like a good idea to me every 10yrs at least. it's pretty cheap and it's a filter... hmmm....
Old 05-25-2010, 01:15 PM
regnar11b's Avatar
Whats the problem? Why do you need to get at the fuel filter?
Old 05-25-2010, 05:51 PM
wrenchtech's Avatar
I bought the 4runner in need of some work. It's running pretty bad, so I'm trying to eliminate all the easy stuff, like cap & rotor, filters, compression test, vacuum test, timing, TPS, AFM, etc. If I had a fuel pressure tester I'd run the test; for now I'm replacing the filter. BTW> Autozone will sell a tester for around $150.00 and the issue a refund when the tester is returned. I'm debating (mostly with myself) whether I should go that route or buy this one for $45.00 and keep it. -- Matt
Charecter1
11-06-2023 10:08 AM
icentropy
09-16-2020 02:47 PM
TURBOrunnerNM
07-22-2015 11:01 AM
redneck17
07-17-2015 07:44 PM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: Where's the Fuel Filter? '89 4runner V6
