What is this stuff??
So my front transmission seal (R150F) starting puking gear oil this week. I was taking out my transmission, and when I took off the transfer case shift lever I noticed this chunky green goop....
My thoughts are it is old grease that has solidified, but I would like the opinions of some other people who have taken these apart...
I really don't want to split the cases and open up the transfer case - but I obviously don't want to put it back together if something is going wrong.
That is your shifter seat. The stock oem ones turn into a mess over time. When you replace it, the shifter will get way tighter and you will be able to find a gear super easy.
I don't think the t. case uses a replaceable seat, the shifter ball just lays in a seat machined into the shifter base.
Look to me like it is just jellyed/decomposed grease that the last person put in when reassembling the unit.
I would carefully clean it out and forget about it. Maybe put a smear of new grease in when it goes together.
Many of the tranny and t. case shifters I have taken out show some rust on the shift rails underneath from water condensation that has got in over the years.
Yours looks good. No worries!!
I could swear that I saw a vid where someone installed a quickshifter on their trans and said they installed the aftermarket Delron shifter seat on their transfer case. I think it was a Marlin Crawler install video.
I'd call Yotamasters and ask them. That's where I got my transmission shifter seat. I suggest them because unless something's changed Marlin Crawler won't answer their phone anymore.
If it was aftermarket, then maybe they used one with their setup.
I have looked through the service manual (I have a digital factory one) and the parts diagrams online - not a single one references to a shifter seat for the transfer case....
I pulled the control retainer off and cleaned everything out. I looked inside as far as I could, and I don't see any signs of it anywhere else. So I am not going to worry about it, and just put it all back together.
live4soccer7
05-11-2016 06:52 PM
83yotastockR
11
11-10-2015 06:54 AM
JookUpVandetti
09-30-2015 08:58 AM
