What is this part number
Old 04-10-2014, 07:06 PM
Gevo's Avatar
Hi guys, I did some searching around and can't seem to find the part I am looking for. I think it's because I do not know what it's called.
It's part of the linkage for an automatic tranny transfer case shifter. A rod connects to the shifter arm under the car, goes to a device that looks much like an idler arm housing (see pick below) and that is a pivot point for the connecting rod to go to the other side (passenger side) of the transfer case to shift it. So, that housing/pivot point is the issue. I need a new one. I can not find the part number... nor do I know the name of it.
Help
Thanks
Old 04-10-2014, 07:20 PM
rworegon's Avatar
This and this may help possibly.
Old 04-10-2014, 10:05 PM
Gevo's Avatar
The terminology on the link you provided helped me to find the part. Thanks!
Part number 33793F is very loose over 33709F, I have to figure out which part needs to be replaced, I didn't realize there are so many involved... I have a feeling its the clip PN 33772F.
Old 04-11-2014, 12:14 AM
wyoming9's Avatar
Red face
Not sure about your numbers all the part numbers I ever use are the 10 digit ones .
Old 04-11-2014, 04:31 AM
rworegon's Avatar
Those numbers are what Toyota calls the PNC (Part Number Code) and the 10 digit part number is linked to the PNC. Take a look at the second link I posted above.
Old 04-11-2014, 04:38 AM
wyoming9's Avatar
Red face
If I go in to my parts guys I would need to tell them what the PNC is and where to find it.
Just a got a trainee it has been really rough.
Just when I get the Parts Manager trained to find really old parts He leaves.
Old 04-11-2014, 08:29 AM
Gevo's Avatar
LOL.. that's funny
Most diagrams only show the PNC, then I look at the list of PNC's and use the full part number to check it against the VIN make sure i'm getting the right part.
FOr this issue, I have to take the linkage apart to see what I need to replace. It makes all sorts of vibratory noises down there. I zip-tied it tight to something and the noises stopped.
rushw
07-18-2015 01:46 PM
msane99
07-17-2015 10:13 AM
Fundy Rider
07-16-2015 01:35 AM
msane99
07-11-2015 08:08 PM
cyclist231
07-07-2015 12:56 PM
Quick Reply: What is this part number
