What Bore Size Master Cylinder W/ Rear Wheel ABS?
Hiya, folks,
I'm trying to pin down the CORRECT master cylinder to use with my 1990 SR5 4x4. I have the all important (LOL) rear ABS and I am getting conflicting info.
I currently have sub-par braking but it is *okay* and by no means stellar. Suffice to say everything has been replaced including the LSPV except for stupid the power steering-fed ABS actuator. I currently have a 1" cast iron master on it. I took off the original aluminum one long ago and I cannot remember where I stashed it. I just found what I believe was it last nite but it is a 1.062" bore unit.
Those of you who have this exact same setup, could you please inform this lame-brained poster what master cylinder you have in your truck?
Thanx for the help!
Bud
Thanx for the help!
Bud
kawazx636
10-06-2021 03:03 PM
Odin
09-26-2015 06:56 PM
