valve gurgle?
Old 04-01-2009, 07:06 PM
sinneDBTB's Avatar
valve gurgle?
as some of you know i have been trying to clean-up my intake system and ran into a few snags. (sheared bolt nightmares, broke a $85 VSV and more...) i have now put everything back together and there is a mean gurgling sound coming from what i think may be my valves on the passenger side.
could the timing on that head be out a smidge causing that sound?
i havent taken it for a drive yet, but when i rev the motor the sound goes away at higher rpm's.
thanks
Old 04-02-2009, 12:23 PM
sinneDBTB's Avatar
anyone?
Old 04-02-2009, 01:01 PM
toyota4x4907's Avatar
valve gurgle? never heard that term before...got a sound clip?
Old 04-03-2009, 05:14 PM
sinneDBTB's Avatar
ill go take a clip tonight. i tried fiddling around with the vacuum hoses and it seems to have made a difference. so i guess that would make the noise a vacuum gurgle.
Old 04-03-2009, 08:59 PM
desert-rat660's Avatar
what u talkin about Willis?
Old 04-03-2009, 09:06 PM
sinneDBTB's Avatar
i dtermined that its def not timing and that my gaskets are all good. so i began trying different arrangements of the vac hoses that spagetti the pass. side of the plenum. i managed to clear up the gurgling sound but its still not running quite right.
anyone have a diagram of the vac hose arangement?
Old 04-03-2009, 09:07 PM
I'm betting the PAIR system is leaking
Old 04-03-2009, 09:09 PM
so you just went and randomly attached hoses in different places?
Old 04-03-2009, 09:11 PM
a Simple search yielded so:
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
Old 04-03-2009, 09:15 PM
abecedarian's Avatar
Old 04-03-2009, 10:04 PM
sinneDBTB's Avatar
yes. i tried some different arrangements to test whether that was the problem and wouldnt you know it, it seems it was. i had thought that id returned all the vac hoses to their orig. locations after i put the top end back together.
in heinsight i should have labeled them as i removed them.... another lesson learned the hard way.
Old 04-04-2009, 03:46 PM
hm. Thats funny lol. Better look at the vacuum diagram. I would have posted the picture myself, but for some reason I can't access my Photobucket page
Old 04-04-2009, 03:52 PM
sinneDBTB's Avatar
my apologies. turns out i forgot to connect the main vacuum line to the pair reed valve and thats what was causing the noise. i'll tell you one thing, its a lot easier to connect when the plenum isn't bolted down.
cheers for all the trouble shooting help boys!
Old 04-04-2009, 04:03 PM
Who called it?!
Glad you found it.
LotOMiles
09-14-2015 11:45 PM
ac7822
09-11-2015 08:49 AM
Boomer8404
09-10-2015 09:01 AM
idadan208
09-07-2015 09:06 AM
larrys93pickup
09-06-2015 06:37 AM
Quick Reply: valve gurgle?
