Valve closest to my oil cap
Old 12-23-2016, 03:27 AM
Rumbleweed0302's Avatar
Egr delete
22r
I'm assuming I'm getting blow by from a worn piston ring my valve cover has 2 hoses on top the one closest to my oil cap is blowing out is it suppose too do that. But when input my finger over it sucks in is it hooked up wrong I got it hooked up to my carb.
So I have been thinking bout an egr delete. I know it pollutes the air more but I wanna knowis this a good thing or bad over all does it cause the motor to use more gas Run ruff run better etc
Old 12-23-2016, 09:01 AM
wyoming9's Avatar
Red face
Not real sure just what your trying to do.
It looks like you have two vacuum lines hooked together
I can`t tell for sure but it looks like the thin line comes off the EGR
The big line was part of the stock air cleaner I think been so time since my Carb days
Ok looking closer That thin line should be hooked someplace else .
The breather should go into the air cleaner while the PCV gets vented into the manifold
Have to figure out just what the smaller line is for it very well maybe fine hooked there just not factory for sure
Old 12-23-2016, 07:56 PM
I plugged the thin line I just wasn't for sure if it was suspose to be blowing pressure out of the breather and pcv valve both
Old 12-23-2016, 07:57 PM
I'm gonna get a get delete kit
