v6 gears
well i sent zuk a pm and he said that you can swap v6 gears into a 4cyl 3rd.
this is what he sent me back.
(Ya....did you know that your 22RE 94 has V6 gears in that 4 cylinder 3rd? V6 pinion heads are longer...so the key to making them work is a "shorter inner bearing" so use the oem 90366-35044-77 inner bearing with a 4 cyl carrier.)
Hey Yotamonster-
Just coincidentally, I just now received this info from the guys at http://justdifferentials.com
http://www.nitro-gear.com/articles/
They are dis-continuing "4 cyl" gears in the Nitro line and selling only the "V6" versions. Note that calling them V6 gears is a bit mis-leading but all it means is they have a thicker or longer pinion head. ZUK
Shaun Crystal Gomban
07-30-2015 10:13 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
