Turbo???
Old 10-31-2008, 12:10 AM
layedyota's Avatar
Turbo???
my truck is turboed it does get up and go for and auto!!!! but i want more power i read a t3 t4 would be ok to swap do i have to change a lot to do that??? 775 340 8430
Old 10-31-2008, 04:29 AM
turyota90's Avatar
you need to change the exhaust manifold. i'm pretty sure it's different flanges from stock
Old 10-31-2008, 04:40 AM
saitotiktmdog's Avatar
First off please tell me your truck is not the one in your avatar
But anyway there are adapters you can get for the stock 22r if that is the engine you have but I would recommend the steed speed manifold. Takes up less space, spools up great and is sturdy and much cheaper than most others of same or similar quality. In my opinion it is the best 22r turbo manifold on the market. http://www.steedspeed.com/
Old 10-31-2008, 09:16 AM
layedyota's Avatar
truck is already turboed rte ... and yea that is my tuck lol!!!!! building as every one else here just a little different!!!!
Old 10-31-2008, 09:22 AM
Alex 400's Avatar
Now now. don't judge. Everyone has different tastes and pleasures. THe only thing is, here 98 percent of us are either stock or off road upgraded. He just went the other direction, down low.
Is that on air bags?
Old 10-31-2008, 09:25 AM
Well I hope its at leas a 2wd. Anyways they have dapters for the te manifolds that let you run the garret turbo. I would just upgrade the whole manifold though.
Old 10-31-2008, 09:26 AM
annoyingrob's Avatar
A CT26 off of a Supra is near bolt-on to the stock 22R-TE manifold, and will provide you with a nice boost in power.
Old 10-31-2008, 09:33 AM
layedyota's Avatar
yea 2wd ha haha i love 4x4s ive got my lifted dodge lol!!!!!! yota is bagged and body dropped 3 3/4 inches!!!! sorry if last post sounded mean i go both ways LOL !!!!!
Old 10-31-2008, 09:38 AM
Just as long as by going both ways to mean both lowriders and 4x4s and not well you know what i mean.
Old 10-31-2008, 09:40 AM
layedyota's Avatar
Old 10-31-2008, 09:45 AM
layedyota's Avatar
hahaha ya i searched all nite online trying to find a full dash for mine and this is best place i found ..... so i have bigger injectors gonna run 3 in exaust with t3 t4 hybrid with the stock efi and run 14 lbs of boost so all i need is different headers and intake manifold right???
Old 10-31-2008, 09:46 AM
NICE trucks
Old 10-31-2008, 09:47 AM
Id say the stock intake will work. maybe port it. Different manifold for sure though
Old 10-31-2008, 09:49 AM
layedyota's Avatar
wherre do i find the right one to fit cant fin anything for this truck!!!!!
Old 10-31-2008, 12:21 PM
turyota90's Avatar
i got my turbo header on ebay for a t3. there's a guy that makes them and sells 'em once in awhile. was only around $250.
Old 10-31-2008, 01:21 PM
layedyota's Avatar
righ o thanks that aint to bad
Old 10-31-2008, 01:35 PM
sh0kk86's Avatar
http://www.toysport.com/Technical%20...tech_notes.htm
Old 10-31-2008, 01:49 PM
space-junk's Avatar
quality sig material up for grabs!!
nice trucks tho... are those escalade rims on the 2wd??
Old 10-31-2008, 02:58 PM
400yzturbo's Avatar
I don't know if this has much to do with what you have going on with the turbo project, but he it goes.
I put a 22re-turbo in place of a 22re and when finished it ran okay. I had it set up with a t3/t4 hybrid turbo, intercooler, blow off valve, 450cc injectors and of course the turbo air flow sensor and ecm.
The first issue I had was it would hit some sort of fuel shut cut, just as it started to build boost and that was annoying. I found that toyota has a fuel shut off that cuts fuel. I won't try to go into detail, but thats what I found. So i tried running 450cc injectors to try and get more fuel before it hit the cut-off. Also I was pushing at first 23lbs of boost and it was a wild truck, but I kept blowing head gaskets, so I dropped the boost to 12 lbs and it did better but didn't solve all my issues.
Sorry, if I get a little off topic,
If I were going to run more boost than recommended I would think about running arp head studs, or you will probably start blowing head gaskets like I was. I had replaced 3 in a period of 300 miles. Not fun.
I hope you have good luck in getting more power.
Old 10-31-2008, 04:01 PM
turyota90's Avatar
if you're interested, i can find out where it came from and maybe someone to contact
Quick Reply: Turbo???
