Trouble Checking Codes
Guest
Posts: n/a
I have read the different write ups on checking codes and this is the first time I have tried to do it. I connect a jumper (paper clip) from TE1 to E1 on my 1994 4runner auto with the 3.0. When I turn the key on the check engine light and O/D Off light flash continuously. What am I doing wrong? Thanks
when mine does that it is because there aren't any codes there. did you pull the efi fuse first??? if so you cleared the codes already so you will have to wait til the cel comes back on to re-check.
Poncho0206
07-10-2015 06:21 PM
