transmission issues help plz
hey so im having some issues with my 5 speed trany in my 88 pick up 4X4 SR5 it seem after a long trip when i come to a stop and try and put it back in gear it will not let me put it in to gear and will not let me put it in to 2nd 3rd 4th or 5th and you can hear it clunking around and will almost push the truck back and forth until it finally engages, but shifts so smoothly and makes no noise when im driving what could be the issue?
thanks
thanks
Check your master and slave cylinders for leakage. Master is next to the brake booster and Slave is on right side where engine meet transmission.
Check the clutch ^ like he said.
You're transmission should be fine "with those symptons you described".
That's what I meant- check there's fluid in the clutch cylinder. and bleed it too.
typically, not going into gear at a stop, but going into gear easily while rolling, is indicator of hydraulic issue. do a really thorough re-bleed of the clutch slave cyl. i mean, really thorough. of course, check for obvious leakage before you start.
then like the guys said before, check the travel at the pedal, confirm the rod is actuating fully, and a pedal bracket crack hasn't occurred.
then i'd suspect a failed throwout bearing if you used discount parts on that last replacement. only after that i'd start wondering about the trans itself.
good luck!
it is my syncro it has been messed up since i bought the truck. when i got the clutch done profetionaly they told me dont worry about that it wont cause any issues or damage..................... bunch of bull˟˟˟˟ters wanting to make more money off me. im going to replace my syncro this weekend. ill let you know if that fixes the problem.
any one who lives in victoria BC Canada dont go to bullfrog transmition. theyll ripe you off just like they did to me. i should have put 2 and 2 together when some radom came up to me pissed off and asked if they did trany work for me then stormed in to the office.
FS[PacNorWest]: Really Nice Truck on WA craigslist
Esibnitsud
07-21-2015 08:51 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
