Transmission cooler question
Which is the return line to the transmission from the cooler? I want to install a temp gauge on the return line, to make sure my cooler is getting the job done.
Thanks.
Thanks.
doesn't a typical trans temp sender for an aux gauge get put onto the trans pan? I don't know that's why I am asking, but I have also seen them put on a test port of a transmission too. Not sure if the yota trans has one of those though. But I guess the return line is the same as the pan right?
mYnAmEiSmUd
07-20-2015 06:48 AM
