Toyota pickup 4x4 94
When in 2wd drives fine lock in 4wd makes vicious clicking sound have changed inner and outer tie rods the manual locking hubs and idler arm still doing it any ideas
Oil in your front diff? Fluid in transfer case?
If both of those, then my guess would be CV axles over front driveshaft, as driveshaft should be more a chirping if just U joint going bad provided you haven't completely broken a U Joint -- if broken then U joint will click.
