Tire/Gear ???
Old 03-01-2008, 02:05 PM
YeloSub7's Avatar
Tire/Gear ???
Alright, well I have a 90' 4Runner 22RE 5speed now to work on
Going to be installing some cruiser coils and bj spacers next week
I want to run 32s instead of cramming 33s under there so I don;t have to deal with rubbing and more mods/lift... anyways I was wondering what gearing I should use (4.10s atm) 4.56 or 4.88 with my engine/tranny setup? Not many 2nd gens on here with the 4 banger, but anyone with help or ideas will be greatly appreciated!
As of right now I don't need to dd it, but it may be that down the road... sorry to be difficult
Old 03-01-2008, 02:14 PM
Jay351's Avatar
Go with 4.88 gears. You will rev higher then stock, but you will have more lower end grunt. Great for accelerating or passing.
Old 03-01-2008, 02:56 PM
elripster's Avatar
I'd go with 4.88's too. Plus, should you ever decide on 33's, while it won't accelerate as quickly, you will at least have the option.
Frank
Old 03-01-2008, 05:12 PM
YeloSub7's Avatar
good point... will I still be able to drive at hwy speeds (65mph) without reving too high tho? I just know that 4.56 gears from other stock toys are easy to find compared to 4.88. And I don't wanna pay the big bucks to have new ones installed, and I've never done those myself and don't know if I trust myself with something that delicate. Sounds like I should just be patient and get 4.88's then... thanks for the info
Soooo, anyone have any 4.88's?
Old 03-01-2008, 05:17 PM
GenXr's Avatar
I have a front 4.88 R&P I'll sell you.
Old 03-01-2008, 05:34 PM
YeloSub7's Avatar
Sweet! pm'd ya...
Old 03-01-2008, 05:35 PM
YeloSub7's Avatar
Or should I still go with the 4.88's and go with the 33x10.5? Or will I really gain much with those over 32x11.5?
Old 03-01-2008, 05:44 PM
YeloSub7's Avatar
sorry one more ? If I go 33x10.5 I will probably go with the rims I have on now, but if I go 32s I was thinking of using some other rims that are 15x8 with 3.5 or 3.75 backspacing, cant remember... any thoughts of rim size for either tire? Well, as far as clearance/rubbing issues?
Old 03-01-2008, 06:11 PM
GenXr's Avatar
If you run 4.88 gears you'll be happier with the 33's all around.
Old 03-01-2008, 07:58 PM
YeloSub7's Avatar
AH!! I don't know what to do... I am leaning more towards running 32's, any more thoughts from anyone else before I bite the bullet and just buy these 4.88's from GenXr
Old 03-02-2008, 01:19 PM
YeloSub7's Avatar
so would 4.88's be ok with 32's? With a 22re & 5 speed on this 2nd gen? As a dd?
Old 03-02-2008, 01:40 PM
Jay351's Avatar
Yes, it will be fine.
If you go with a rim with less backspacing then stock (4.75) you might run into rubbing issues depending if you run a wide wheel/rim combo.
If you can, find some factory 4.88 gears from a automatic 4runner or truck (with factory 31" tires) They can be had pretty cheap, and are stronger then any aftermarket R&P you can buy.
go with 4.88's with a 32-33" tire, no matter the width. It will rev a little higher, but thats okay. If you were driving at 80mph all the time then you would want 4.56 gears.
Old 03-03-2008, 02:52 AM
YeloSub7's Avatar
Thanks MATT! So I got a 4.88 rear third with a limited slip, no I need a front 7.5 ifs third... anyone? preferably open.
Old 03-03-2008, 05:32 AM
Fizboy's Avatar
I run 33x10.5 15 on stock rims and no BJ spacers with minimal rubbing on the sway bar. I have 4.56 stock gears, but of course I have the V6 with a tiny bit more power but you have better torque. I like the thinner tire for the eastern mud and such. They do great for the long highway drives as well. The 4.88s will be better with the 4 banger and 33's. More low end torque for off road.
Old 03-03-2008, 04:38 PM
Alindqu1's Avatar
how is the power with the v6 with 33 and 4.56?
Old 03-04-2008, 12:17 PM
YeloSub7's Avatar
I ran this same setup on my old 94' runner, and it wasn't too bad, but the gas mileage suffered... I would still go with 4.88's, but as far as power it still wokred fine for me
Old 03-04-2008, 12:35 PM
alpine4x4's Avatar
I ran the stock 4.56 gears with the V6 pickup 5 speed and 35" BFG mudders and it ran just fine.
Guyechka
06-16-2010 02:57 PM
cpizzle42
10
12-17-2009 09:38 PM
teamjbl
11-24-2007 11:49 PM
Quick Reply: Tire/Gear ???
