throttle cable?
Old 10-16-2008, 12:12 PM
~jack~'s Avatar
throttle cable?
So i changed the oil in my runner the other day, and when i started her back up she was running at about 3 grand idling. Shut her down and after a bit of messing with it it turned out the cable was kinked. Unkinked it and it ran fine for a bit. Later turned it on and the opposite was happening. Would not stay at idle, as soon as you let off the gas it would drop rpms until it stalled. While messing with it again i blew a relay turning it on so am awaiting that to mess with it more. pretty sure this is the throttle cable but am i wrong?
Old 10-16-2008, 12:27 PM
abecedarian's Avatar
so, the oil cap is tight and the dipstick is in good too? sounds dumb, but vacuum leaks can occur if not.
Old 10-16-2008, 12:33 PM
~jack~'s Avatar
k thanks for the heads up ill check for sure
some drunk guy
08-03-2021 06:09 PM
Williamemslie
14
10-05-2015 09:28 AM
Sam hain
19
09-30-2015 08:25 AM
Shaun Crystal Gomban
09-20-2015 11:16 PM
toyotafreak98
09-10-2015 02:57 PM
Quick Reply: throttle cable?
