super bouncy front end, newbie needs help
Old 02-01-2010, 07:07 AM
lordhowe's Avatar
I have a 92 v6 5 speed 4wd 4runner. It's got a set of ball joint spacer lift and rear coil spacers (1.5" - 2"). I managed to fit 33x12.50's mud terrains.
The front end of the car is always bouncy and I even soften up the torsion bars in hopes to make it less bouncy. the car now articulates decent since the torsion bar adjust but it would bounce pretty hard even coming off of a curb (my bounce test ). i recently got a set of advanced auto parts struts in hopes that will cure my bounce issue but today i realized that the bottom mount of the shock (the loop where the bolt goes into) is ripped clean off.
what can I do to fix these issue? do i need a beefier shock? any help would be great.
thanks
Old 02-01-2010, 07:11 AM
Blue Bowtie's Avatar
Sounds like you need some longer shocks.
Old 02-01-2010, 07:21 AM
MaK92-4RnR's Avatar
shocks...
Old 02-01-2010, 07:35 AM
lordhowe's Avatar
It does look like i need some longer shocks, what's the guide line on picking out shocks that are longer? should i just go with one that's 3" longer when fully uncompressed or is there some math involved?
thanks alot!
Old 02-01-2010, 10:43 AM
lordhowe's Avatar
front shock question
I have a 92 4runner v6 5speed with 4WD. I did a front ball joint spacer lift and a rear coil lift and managed to fit 33x12.50's. however the front is extremely stiff and bounces even after trying to loosen the torsion bar. The front is so stiff that the front shocks are pulled apart.
what size of the shock should i be looking for? specifically, what are some of the cheaper solutions to get my rig back up and running? I'm looking to spend no more than 150 bucks on the front pair.
thanks a bunch.
Old 02-01-2010, 10:06 PM
limon32's Avatar
I've got KYBs in the front the PO put on and they perform well, I typically run 50mph on the beach and dunes with acceptable performance. I put ProComp ES9000s on the rear and they are great, I'll get some for the front when I get around to it. I think you can get some around your price range.
Old 02-01-2010, 10:26 PM
olharleyman's Avatar
4wheel.com
http://www.4wheelparts.com/Lift-Kits...ShockingES9000
Tell them you want a set for a 4" lift
Old 02-02-2010, 05:54 AM
lordhowe's Avatar
thanks alot guys!
is 4" too much or is this going to be okay? i think my spacer did anywhere between 1.5 to 2" lift and the tires helped a bit but i don't know if that's part of the calculation. sorry for being such a newbie, this offroad thing is new to me.
thanks
Flying91
45
04-11-2024 04:39 PM
06-01-2021 01:51 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: super bouncy front end, newbie needs help
