Strongest Clutch Upgrade 86 4runner Expedition build
I need to replace my clutch ASAP, and want to upgrade flywheel and any other components at the same time. Any suggestions of brands that will best accommodate more weight/bigger tires/trailer towing. I'm currently looking over all others builds. Thx
I would worry more about hydraulic failure then the clutch hard parts.
One can nurse a failing clutch quite a distance.
Now if your talking enough torque in the engine to just twist the center out of the clutch that is a different story.
Then different climates one looks at different things in a build of this type.
I just realized LCE's in the clutch game now. Interesting...
I might order from LCE tomorrow, the clutch kit with the 30lb flywheel. I need to repair asap. I would replace master/slave also. Has anyone used LCE? Is it rebranded Trail Gear?
Muddpigg... You are down in SA? That's my destination from Montana after I get a new clutch installed! Now I'm looking at stock clutch Stay tuned...
ak4rnr
05-13-2016 07:52 PM
captainslow
02-08-2016 09:10 PM
