Sticky hubs
Old 08-29-2012, 05:42 PM
woodyth's Avatar
Sticky hubs
I can't unlock my hub on my passenger side. I had to use a wrench, stuck in the mud up on the trail to get it in to get out of being stuck but now I can't get it to unlock. What do i do? I have never done anything to these hubs.
Maybe the Wabbit will feel some sort of charity and DONATE to my new hub cause!?!?!?!?! LOL or maybe a DEAL? And I'll buy them!
IDEAS?
Woody
Old 08-29-2012, 07:02 PM
ThatGuy1295's Avatar
Could have a bad seal, I know if they get full of water, or to much grease, they can stick locked or unlocked. Reseon being the hydraulic condition created by liquid on one side of the hub gear causes that gear not to be able to slide back N forth. After all there not directly mechanicaly actuated, theres a spring in between the dial and the hub gear itself. SO the dial may turn fine but the hub gear isnt sliding. or somthing like that.
Old 08-29-2012, 07:04 PM
I once over greased mine and they wouldnt work at all. Took some grease back out and they worked fine again.
Old 08-29-2012, 07:07 PM
Ohh you mean the dial was hard to turn?
If thats the case id just rebiuld/clean all the parts in the outer hub.
Old 08-29-2012, 07:08 PM
woodyth's Avatar
yes like would NOT turn
woodyth's Avatar
I know it locked in because it was slinging mud
Old 08-29-2012, 07:18 PM
You just sounds like its sticky. Pull the outer hub and clean up the dial mechanisms.
Old 08-29-2012, 07:43 PM
TrikeKid's Avatar
Pull the outter hub and put some grease or anti-seize on the hub gear. Had this problem when I bought my most recent pickup, someone pulled the hubs apart and cleaned them, then assembled them bone dry. Was glad I figured it out before I really needed 4wd.
Old 08-29-2012, 07:45 PM
thats a good idea
Old 08-30-2012, 04:44 AM
waskillywabbit's Avatar
If it won't turn you busted something or you didn't use your big purse.
:wabbit2:
Old 08-30-2012, 05:45 AM
purse
Old 08-30-2012, 01:14 PM
peow130's Avatar
I had this problem the first time i submerged my hub when it was cold out. Unrelated anyways.
Pull the hub face, and hub body. Clean them both really well and use some MARINE GRADE GREASE on them, that won't wash off.
Mine turn like butter after several submergings.
Old 09-02-2012, 02:29 PM
Nick Foster's Avatar
Yeah just pull it apart, clean it, and re-grease it. Marine grease for sure
ladybugRC
458
08-21-2020 10:41 AM
G-off
12-29-2015 12:44 PM
AaronM
12
11-04-2015 04:06 PM
stanz
10-30-2015 10:33 AM
Toys4parts
09-26-2015 01:56 PM
Quick Reply: Sticky hubs
