Steering Stabilizer Woes
Old 01-14-2010, 01:38 PM
Jody's Avatar
I recently replaced the steering stabilizer on my 94 p/u with a pro-comp unit. Unfortunately because the Pro-comp shock is so much thicker, when turning the wheel all the way to the right, the steering shock contacts the stop for the pitmann arm before the idler arm hits it's stop, thus limiting my turning radius... Anyone else run into this problem?
Old 01-14-2010, 01:40 PM
pntbol11's Avatar
I have a a Pro Comp ES3000 stabilizer and mine works fine. It sounds like you have the wrong part. Is the shock compressing all the way?
Old 01-14-2010, 01:43 PM
Jody's Avatar
I believe mine was an ES3000 as well, It'll compress all the way, it just won't extend all the way because the nut and body of the shock runs into the pittman arm stop. Hope I'm making sense here...
Old 01-14-2010, 01:46 PM
xxxtreme22r's Avatar
i remember mine doing the same thing, I can't for the life of me remember what i did to correct it. I'll let you know as I have to put mine back on tomorrow. yours is mounted like this right:
http://www.explorerprocomp.com/PDFs/is/2504.pdf
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
live4soccer7
05-11-2016 06:52 PM
scott90
10-04-2015 09:21 AM
ktm192k
10-01-2015 08:47 AM
Quick Reply: Steering Stabilizer Woes
