Starter issues
Starter issues
I've tried looking up threads on here with my concerns, but haven't had much luck...if anyone can point me in the right direction, please do! Otherwise.....
I have a starting problem. Yes, another one of these threads! Here's mine: sometimes my truck won't start. The relay clicks, and I can hear the cold start injector injecting, but not even a click from the starter itself. This usually happens when I've driven for a while. It's like, after I turn the truck off for a few minutes and something gets heat soaked, then it happens...but not 100% of the time either.
I've checked the relay, and it clicks when power is applied. I've also changed the starter contacts with a set bought from the Toyota dealer. Still, the problem persists.
When this happens, using the clutch cancel switch or depressing the clutch has no effect. In order to start it then, I have to pop my hood, get out, pull the cold start injector connector off, then use a wire from there straight to the battery, and it will start every single time.
My starter is a Napa starter, not the OEM. Could this have something to do with it? My co-worker says he went through 4 Napa starters on his Toyota van before finally getting a Toyota starter, and the problem went away...I don't want to spend $150 on a reman Toyota starter if I'm not even sure that's the problem.
My truck is an '89 Toyota 4Runner, with the v6, manual transmission, and 4wd. HELP!!!
Had the same problem for a while, replaced the starter, ignition switch, checked all the grounds, redid the connections (cleaned them) etc etc etc.
Installed a Hot Shot kit and the problem is gone.
I just replaced my starter on my 3.0L and now my truck starts like a charm... But my had been failing much like yours for quite some time. and i was milking it.
Lifetime warranty at O'Reily's was only 73.99...
A starter relay kit:
- http://www.4crawler.com/4x4/CheapTri...l#OtherOptions
imo, should stay away from non factory starters. your better off buying a junkyard oem starter and changing the contacts on that. even rebuilding one completely is better than any autostore starter. you usually get a click from the starter if the contacts are worn, since your not getting a click. it could be a bad solenoid in the starter or a weak relay. another thing i have seen alot is if your battery terminal is not tight. like you can grab each wire at the battery and twist it. if you got movement. tighten them down or replace the terminal if its already worn out. corrosion on the wire to the starter is another i would check
This morning, it acted up, so I whacked the starter relay a few times and then it started right up. Coincidence? Maybe.
So I took the starter relay apart. Looked good. Next: take a look at the ignition switch. Wires look good, and no broken solders. I know, that doesn't mean it's good. Cleaned the little wear there was between the contacts a bit with fine sandpaper and put back together.
Then was told next time it acts up, try wriggling the key around inside, that it might work. Or tilt the steering up and down a couple of times. If any of those two work, it might be the switch.
But then it totally slipped my mind: I have an alarm system on there, and of course it's hooked up to the ignition somehow. It looks like there's some kind of relay for the alarm, with wires going everywhere. I'll have to check there next.
Update:
The starter problem has persisted, and had gotten worse lately, so I 'fessed up and got a remanufactured OEM starter from my workplace (Toyota). It cost me an arm and a leg, but I no longer have the problem. It's been 2 weeks now, and I haven't had a problem yet.
You most likely have a voltage drop to your solenoid wire. A new starter is likely to be a temporary fix, since once it breaks in and needs more voltage, you will have intermittant problems again. Your friend going through 4 NAPA starters likely also was not getting enough voltage to the solenoid if it was an older vehicle. All older toyotas will benefit from the starter relay kit since they have voltage drop by design., and the solenoid needs a fair kick.
What starter relay kit are you referring too? I have an 87 runner with a similar problem, it has gone away but I fear it will return. I did a multiple of things. Does this relay kit work for the 4cylinder 22re?
mluz013
08-02-2015 05:00 AM
ZONAYODA
07-13-2015 07:17 PM
