Last edit by: IB Advertising
Browse all: Interior Guides
- Toyota 4Runner 1984-1995 How to Swap Gauge Cluster
Step by step instructions for do-it-yourself repairs
SR5 Gauge Cluster Swap - How-to, with pics!
#345
Thanks for the great writeup. I'd thought I would add some photos of a electronic odometer swap. I changed my miles this way without removing the speedometer needle.
Picture of a electronic piece:
Attachment 183215
Remove this black finger looking piece first. Just pops right out.
Attachment 183216
I used a ice pick to push out the rod(no. 1)
Remove the white gears(No. 2)
You should be able to set the miles to the correct reading by just turning them freely. You'll need some patient putting it back together. Slide the rod back in while placing the white gears on one at a time. Keep checking to make sure the miles are still reading correctly. Put the black finger thing in.
Attachment 183217
Attachment 183218
Attachment 183219
Attachment 183215
Attachment 183216
Attachment 183217
Attachment 183218
Attachment 183219
I know this is an old post but I'm doing this swap and can't get the rod out to correct the new odometer. Was there any trick to it? No matter how hard I push on it, it won't give, so much so that I'm afraid that I might break the plastic haha. Any tips?
#347
Thanks for the write-up. Do you have a Part Number for the correct "SR5 Oil Pressure Sending Unit" to fit to the 22RE to make the new gauge cluster work? For an electronic cluster, does the tachometer need to be calibrated or does the cluster automatically recognize either a V6 or 4 cylinder applications? My switch is for an electric cluster, so I'm having the speedometer shop correct the odometer and need to tell him if her needs to calibrate the tachometer to 68.3 ohms or not.
#348
#349
Great write up, my install went pretty smooth. I have a problem with my speedometer though, it seems to be registering about 10-15 mph faster than I'm actually going while at highway speeds. I almost crapped myself this morning when I looked down to see the gauge reading 90, so I checked GPS which said 75. Any Idea how to fix this? '91 4x4 4Runner V6 cable cluster -> '91 2-wheel PU x-cab.
#350
#351
Depends on the transmission. What I don't know is if you can replace just the driven gear, of if the driving gear has to be replaced as well.
https://parts.lakelandtoyota.com/sho...3911544#33403G
#354
Hey guys, I just swapped my cluster out. If anyone with a stock 22re and W55 (stock rear end) could give some speeds and RPM ranges at those speeds that would be awesome. Say, 5th gear at 60mph =?rpm? This would help people make sure their set up is working properly.
Also, I changed out the oil pressure sending unit, and the gauge is not reading. I think I have a bad gauge in the cluster. Because the sending unit cost me $50, I took it back and got my money. I am just going to install a autometer electronic gauge, which should be better anyway, and only about $60-70. Right now I have a check engine light, likely because I do not have the idiot light sensor plugged in. I'm just going to leave it plugged in so the light goes off... anyone see a problem with that if the cluster is already screwed up?
Jon
EDIT: my truck is a 95 base pickup. My tach was not working so I had to run the wire from the P marked screw on the cluster to the yellow wire on the ignition near the coil. I just opened up the connector, put a skinny wire in, and plugged it back up. No splice needed.
Jon
Can you by chance show me how you did this. I want my tach to work
#355
I just did this swap today, thanks to superbleeder and twistedsymphony! I dont know if this question has been answered or not yet, but i figured it out, and borrowed one of 'bleeders pics to illustrate the how to for anyone who is having this problem. I already had a sunpro tach in my truck before i started, so i had already run a wire from my ignition coil into the cab. If you havent gotten that far, you need to splice a wire into the ground side of the ignition coil. (on my '93 there is a tan and a black wire, the ground is the black wire). then run the other end of the wire either into the 6th position from the left on the blue connector, or attach the wire directly to the screw labeled "P" on the back of the cluster. I had problems with the wire trying to short across other pins so I attached it directly to the screw. Here is the pic I borrowed and circled the pin/screw:
#356
Gwt out your service manual (FSM) flip thru to the cluster pages and locate the tach/RPM pin (from what I remember it's some where on the C connector), you need to connect this to the RPM on the diagnostics port under the hood.. I don't think I took any pictures, but I spend "all day" at the junkyard getting the factory wire out of a dash harness..
#357
#358
Help with gauges.
This seems like a popular thread so I have two questions.
1) how do I remove the lens of the cluster so I can fix my tach needle? My fuse popped one day and my needle went screwy and ended up INDER the nipple at Zero, so now when the truck is running, it raises to there and stops
2) can anyone give me the part number for the bulbs that go in behind the gauges. NONE of mine work lol
I've searched all over this site and can’t seem to find the answer anywhere.
Many help is greatly appreciated.
Picture for clarification.
Also this is the original cluster with (from what I can tell) the original drive train. I’m not sure if it’s common or not, but the mileage impressed me
#359
If I remember correctly, there are six plastic tabs holding the clear face lense to the gage cluster. Gently pry (lift) each away from their cluster housing bases and the lense will pull free from the cluster housing. The following pic shows the location of the tach adjusting screw. It only takes very slight adjustments to dial-in the correct tach setting to reflect 2,900 RPM at 70 MPH for a 22RE.
[img]blob:https://www.yotatech.com/d1268e1b-cb90-4731-b8c7-d8af2ec45bfd[/img]
