SR5 gage swap - had to re-wire connector
Old 08-07-2009, 02:16 PM
fordmgt1's Avatar
Ok, bought an 87 auto sr5 gage to put into my 86 delux. Everything looks close, but I had to move two wires for the fuel gage over one pin.
On the blue (A) connector I had to move every wire over except one for the temp gage over one pin to get the tach to work. This matched up with the 87 wire harness that I cut out.
Now everything works except the temp gage. It goes past 1/4 almost to 1/2 and stays there. I unplug the blue connector and it stays there. It will go there with only the C connector plugged in. the actual pin for the temp gage (by following the circuit board) is on the blue connector. But the temp gage goes up with the blue connector disconnected.
Anyone have anythoughts on this? I can't find any info on this particular situation. Thanks for the help.
Old 08-08-2009, 06:47 AM
fordmgt1's Avatar
time to go through the FSM wiring diagram
Old 12-18-2010, 07:42 PM
tfan's Avatar
Anybody got any ideas on this one - seem to be having the same issue - was thinking it could be the sender but after some testing the sender is fine - it works with the old gauge fine, works with a thermostatic analog AM gauge fine too....... ????!!???
Flying91
45
04-11-2024 04:39 PM
bigjstang
08-25-2021 12:41 AM
steve miller
10-10-2015 01:40 AM
88yodabasket
07-13-2015 01:32 PM
Jonny246
07-12-2015 04:51 AM
Quick Reply: SR5 gage swap - had to re-wire connector
