speedometer on 87
speedometer on 87
ive been looking for an hr. for thred. yesterday speedo started goin upto 70 in second gear and seems to go normal the faster i go. pulled gear this morning and looks fine. pullled cluster and head. no visual wear. it also is slow to go to zero when stoppin. reassembled and worse now. help or guide me to thred please!!!!!!
Not sure if Toyotas are like this, but some speedo cables can be removed from the cable housing so you can put some lube on it. Can't remember which end you pull it out though. Isn't the speedo the electrical speed sensor type?
Phantez
09-30-2015 08:24 AM
charlie_fong
09-27-2015 10:06 PM
Rickstwowheels
09-21-2015 05:21 AM
