spark plug issues T_T
Old 01-12-2009, 03:07 PM
xzyragon's Avatar
Well, i did a spark test, no ignition sparks...
just installed a distributor, but made sure that it was installed correctly. The engine will crank but not turn over. Would not having the engine at TDC make the difference?
NEway, i was in a crash so it is very likely that there is a wiring problem. I don't know how to check if the ingniter assy works (i hope it does), but I am assuming everything is fine since the crash.
BTW... the distributor is connected, wires are in the right positions, dist. is connected to the igniter assy, and the power works. Is there something I need to connect just to run the engine?
Old 01-12-2009, 05:29 PM
Jay351's Avatar
Check if you are getting spark to the dist from the igniter.
If not, swap it out with a used unit. Same thing happend to me when my t-belt snapped. What a coinidence haha!
Eggslinger
06-08-2019 03:32 PM
Alex Bessinger
08-31-2015 09:17 AM
cars-guy
07-11-2015 07:51 PM
smiley52
07-11-2015 05:16 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: spark plug issues T_T
