Some people shouldn't wrench on their junk
i have been smelling coolant for the last couple of days when i would get out of my truck. today i got off kinda early. when i arrived at the house i could smell coolant pretty strong, so i climbed under the truck, and found no real big leaks. i pulled the truck into the garage, left the engine running, and climbed under the truck again, and this time i found the leak. the metal pipe that connects to the intake manifold, the one with the o-ring, was leaking. grabbed my 10mm socket and went to tighten the bolts, and it broke with very little pressure. great. now i have a broken bolt in the intake. i drained the radiator, and let things cool down a little, and then i remove the second bolt, and removed the pipe, and as luck would have it, there was a 3/32" sticking out of the manifold, and with a flat blade screw driver, removed the broken bolt. the PO was trying to fix the leak by tightening the bolts, but the o-ring was broke. i have been fixing stupid stuff like this for a month now. if he owned a torque wrench, he surely could not read it. end of rant. thanks for listening...
.....some people have all the luck. Apparently, you're not one of them.......
Sorry to hear that, tortis. I know it's a pain.
Sounds familiar the guy i bought my truck sounds the like the same guy....i have been fixing little crap here and there that he has destroyed....worst was all the drain and fill plugs....all of them were so rounded and chewed up and stripped...one had a little hole in it where it looked like he tried to take a screwdriver and twist it....i have almost gotten them all fixed....the last one i need to do is the tranny and that one is tore up.....he could of bought replacements at the dealers or from marlin like i did for nothing...POS
Those bolts were a pain in the ass...
I didn't want to risk having them leak seeing as though they were so hard to get to so I used some RTV on it. No leaks so far and its been a year.
not. it seems that the bolts are over torqued, or loose, or like the starter nut, missing. i was guessing loose on that bolt.
i should have taken a picture of his wiring for the stereo. what a mess.
overdrive, that is what i usually do. the dealer can't find the o-ring on their software, so i will make one for this truck like i did the 4runner.
You know, after thinking about it there wasn't an oring for that in my top end kit so I actually took one of the extra gaskets for the egr that was in the kit (must have been 5 different egr gaskets) and I trimmed it a little to fit and then permatexed the heck out of it. Like I said though, it hasn't leaked a drop yet.
The guy that had mine before me had tried to remove the power steering pump pulley (trying to replace the pump I'm guessing, as that's when I discovered this) I think
I don't think he ever got the bolt out, he had rounded the head off so bad I had to get out the dremel and take it down a few sizes, and it wasn't hard at all to get off, neither was the pulley?
If he did get it off, then why the hell didn't he replace it? It was obviously rounded all to hell? who knows? it may have even been the dealership when they did the HG recall
The second day I owned my 4Runner, the timing chain snapped because the previous owner had not used thread locker/ not tightened the bolt holding the chain guide to the block. The bolt came loose, and fell in between the sprocket and the chain. He also killed the AFM with a screwdriver. I don't know how it ran at all. A coolant hose isn't too much to worry about.
I became the Permatex king when I did my topend... I found that blue works best around water, black anywhere oil comes in contact with the gasket, and gray everywhere else.
i didn't crank on anything, and i guess i used the wrong term. i used my quarter inch socket, and i probably only turned it an eighth of an inch. the reason i used my quarter inch socket was because i could not get my torque wrench in there.
You know, sometimes turning a wrench is all it takes to stop a leak. Obviously, not in this case, but sometimes....
Broken my fair share with a 1/4" drive socket, I still have a missing bolt on my right front hub from wrenching with a 1/4" socket set. I just never have replaced it.
Still strikes me as funny your are pedalling pretty fast to justify what YOU did, but slam the PO.
Most automotive stores have both metric and SAE o-ring kits. Both of which are also part of my tool box. At least two of the most common sizes are there as well.
