She's Flat
Old 06-22-2013, 06:16 PM
ksti's Avatar
She's Flat
I don't drive my truck much, weekends mainly.
The last couple times I've driven it I notice that when I accelerate from 2nd gear to 3rd it goes flat, like it's holding back, not bogging just a lack of power.
Maybe a mile later or after a stop light its fine, plenty of power no flatness.
All the maintenance is always up to date, tune-up, fuel filter TB and goodies, TPS, filters, oil changes.
It usually runs fine with no problems, starts right up, good idle and no codes stored.
God, i hope it's not some new gremlin.
Any thoughts on this are appreciated
Old 06-22-2013, 08:08 PM
Toyota~Boy's Avatar
Year make model and engine. Carb or EFI. If carb what kind.
Old 06-22-2013, 08:09 PM
Toyota~Boy's Avatar
Oh I only have Internet access from my phone which uses the YT App. I cannot see signatures so sorry if the info I asked for is in your sig
Old 06-23-2013, 04:32 AM
bone collector's Avatar
well start with the basics first, whats the timing at? idle speed correct? whens the last time you changed the fuel filter? could it need some fuel injector cleaner to prevent some gumming up of the injectors? just some thoughts.
Toyota boy, its a 94 2wd 3vze 5 speed
Old 06-23-2013, 07:50 AM
ksti's Avatar
[QUOTE=bone collector;52089341]well start with the basics first, whats the timing at? idle speed correct? whens the last time you changed the fuel filter? could it need some fuel injector cleaner to prevent some gumming up of the injectors? just some thoughts.
Toyota boy, its a 94 2wd 3vze 5 speed[/QUOTE
Basically most everything pertaining has been changed within the last 5,000
miles. I don't drive it that much, mainly on weekends.
It just intermittent, out of nowhere it just happens.
I,m going to run some injector cleaner today, maybe that will help IDK.
Thanks for the input.
Old 06-23-2013, 07:53 AM
intermittent problems are the worst. good luck and take notes of when it happens, conditions, weather conditions etc etc.... good luck
kawazx636
10-06-2021 03:03 PM
4x4YOTA
08-23-2016 09:08 AM
Brodetski
09-30-2015 11:50 PM
hiluxinargentina
09-30-2015 05:51 PM
ktm192k
09-24-2015 03:36 PM
Quick Reply: She's Flat
