Scored NOS Downey IFS Truss
Old 05-16-2017, 03:43 PM
millball's Avatar
Here's something you don't see every day. I'll put it on the ol Junkrunner.
Old 05-16-2017, 11:55 PM
wyoming9's Avatar
Red face
Did they really help all that much or were they a Mall Crawler option??
Old 05-17-2017, 02:04 AM
coryc85's Avatar
Cool millball, where did you find it? I have one I bought used a few years ago. I have no evidence that it does anything, but I can certainly see that maybe it helps hold frame horns in place, especially beating up the ifs with bigger tires and bj spacers.
Old 05-17-2017, 07:06 AM
MaK92-4RnR's Avatar
In my experience, that ifs brace did nothing. To be honest, putting 35s on IFS isn't as bad as everyone in the past has mentioned. Generally speaking, the idler arm might wear out faster but even then if you replace it, put brass bushings in it and add a brace. you'll be solid.
Old 05-17-2017, 07:12 AM
millball's Avatar
I think their claim was that the truss protected against frame horn and rear A-frame lug spreading caused by repetitive hard suspension bottoming.
Many different outfits offered similar trusses, some bolt-on others weld-on.
At any rate, can't hurt to bolt it up.
Old 05-21-2017, 09:22 AM
ewong's Avatar
It was - as I recall - a PITA to install (circa 1990)
Tho back then I had dull bits and a tiny home "black and decker" drill...
Probably less of an issue today as I would use new bits, and decent cutting oil....
Old 05-22-2017, 03:21 PM
rattlewagon's Avatar
Its worth putting on just because it Downey. Haha.
I still have a few leafs left from my Downey pack in my rufs. Haha.
