rust and rot frame
rust and rot frame
hello
1992 toyota pickup 22re 2wd Pennsylvania
i paid 1.9k for this truck but not knowing how much worse until i hit it with a hammer and found more than i expected, it is my first truck, now is toyota still replacing frame as part of recall or only to 95-00 tacomas?
i have welded patch 1/8 steel plate on some area of the frame, but it still too many rust hole
PO also welded some steel plate but they were rotted out and crack, i had to fix that by cutting PO steel plate and welding new plate in
problem area is around rear leaf spring mount bracket the most
parts replaced:
clutch/pressure plate/flywheel
4 shocks
ebay Headgasket timing chain tensioner kit
head bolts
all fluids
wiper blade
added tachometer
headlights
front brake caliper
spark plug and ignition wire
welded new glass pack muffler
spent a $grand on part
parts replaced:
4 shocks
head bolts
all fluids
wiper blade
added tachometer
headlights
front brake caliper
the fuel pump bracket is rusted out as with the fuel line, they will need to be replace but i dont want to spend lot of money on it
i reside at Glenside 19038
Jcrawl94
10
10-24-2015 04:34 PM
FS[PacSouthWest]: FS: 1988 4RUNNER FRAME 4X4 IFS Located in Lancaster Ca
4x4-runner
08-30-2015 08:55 AM
4x4-runner
08-02-2015 09:24 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
