runs off ether
runs off ether
Ok I have an 88 pickup just put a 93 22re in it to replace the blown up one it has spark and fuel and is in time but will not run unless I spray ether in it runs like a raped ape on ether but dies as soon as I stop spraying any help is greatly appreciated thanks in advance
When I was in the Army we used to use ether for cold starts on our Semis and maybe even our old 5 tons. The old timers said that once the engines got some they quickly became dependent on it.
The AFM is the air flow meter. It's the big box right at the driver side front of the engine compartment just after the air cleaner. A large air intake tube goes from it to the throttle body.
If you're spraying ether into the throttle body, you likely have that intake tube disconnected. In that case, there's no air flowing through the AFM. Without air flow, the fuel pump is cut off. This is a safety feature to prevent fire in the case of an accident that stops the engine with the ignition still on.
Connect up your complete air intake system and try again. It'll probably run just fine.
the1998sr5
15
07-14-2020 08:35 PM
coffey50
07-28-2015 10:55 AM
