Rough idle, Shuts off at light, Popping noise - 1988 4runner 3VZE
Hey YotaTech,
My 1988 4runner 3.0 V6 3vze is having some problems. It has really rough idle. It'll shut off when it idles for about 10sec. When I press the gas, there will be no response and I will hear very loud popping noise until I put the gas pedal to the floor and then the 4runner will move. Does anyone know what the problem is? I will send a video soon as well. Please help
I don't have a timing light. Should I follow these steps? Thank you TNyota
https://www.yotatech.com/forums/f128...3-0l-v6-80332/
- Timing light
- Paper clip or piece of wire to use as a jumper
- 12mm wrench
You need a timing light to do that procedure anyway - if you don't want to own one check a parts house, some of them rent a lot of tools free.
Did that with a fuel pressure gauge a while back, basically you buy it, use it, and return it within 72 hours in good shape for 100% refund or you can keep it and all is good there too. I know O'Relly and Advance do that here.
But timing is the first thing I would check with what you are describing.
