Rod Knock Donor engine
Rod Knock Donor engine?
looking at buying this engine to replace mine that has a bad headgasket and rod knock. do you here a rod knock in this engine? oil level was fine. this engine will need a headgasket i saw the milky film under the oil cap.
thanks, all help is appreciated.
