Resetting check engine light 22re
Old 10-26-2013, 09:08 PM
SqWADoosh's Avatar
I have fixed my problem and now would like to reset my CEL to see if I have another. Can anyone tell me what the process is on our trucks?
Old 10-26-2013, 09:35 PM
HighLux's Avatar
unplug the battery for a few minutes
Old 10-27-2013, 05:04 AM
rworegon's Avatar
.....remove the negative battery cable for a minute or so.
Old 10-27-2013, 08:41 AM
SqWADoosh's Avatar
I did do that for at least half an hour....
Old 10-27-2013, 09:01 AM
rworegon's Avatar
....now you need to read the CEL that appeared after the battery was disconnected.
Old 11-02-2013, 11:41 AM
SqWADoosh's Avatar
Is there a fuse to reset codes? I remember seeing it somewhere in the FSM but can not locate it now. If so does anyone know which one?
Old 11-02-2013, 12:09 PM
HighLux's Avatar
take both battery cable off. touch them togther and leave for 20 minutes.
if the light is on after that.....there is something wrong
Old 11-02-2013, 12:28 PM
SqWADoosh's Avatar
Why touch them together?
Old 11-02-2013, 12:35 PM
combatcarl's Avatar
Pull EFI fuse. Under hood. Then bust out some beer, forget where you put the fuse, go find another one, then find original in your pocket. Then replace.
Sent from my NSA screened iPhone using YotaTech
Old 11-02-2013, 12:42 PM
islanti's Avatar
If light still comes on then you didnt fix the issue or theres another. Check code again
Old 11-02-2013, 12:44 PM
SqWADoosh's Avatar
I've heard to pull the one in the kick panel. Now under the hood. Which is it?
Old 11-02-2013, 01:04 PM
islanti's Avatar
Theres a fuse box. Pop off the cover and pull the one labeled EFI (see underside of cover). Take 30 seconds to check your engine oil and the condition of your battery terminals then replace the fuse
Old 11-02-2013, 01:33 PM
combatcarl's Avatar
You can leave out the beer drinking, I guess. But that's how I always seem to do it, along with checking other stuff. It's the fuse box under hood, right fender.
sonic concepts
07-01-2015 02:33 PM
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Resetting check engine light 22re
