Replacing or Reparing the Dashboard Top
Old 05-14-2008, 09:55 PM
yudoggy's Avatar
Can someone let me know how involved it is to replace the top portion of the dashboard? There's a crack in it from stern to bow on the dash from too much sun.
It seems like it's a lot of labor to remove everything not to mention the cost of a replacement. Are there kits out there that will do a good job in repairing it? I guess a dash cover would be the easy way out...
The rig is a 1995 4-runner, thanks!
Old 05-14-2008, 10:02 PM
SpecialScottie's Avatar
Its actually not that much work.
The funny thing is I just took mine off about 20 minutes ago to try and install a 1st gen altimiter. It took about 20 minutes for me. Im sure you could get a used dash in good condition at pick a part.
Old 05-14-2008, 10:07 PM
http://personal.utulsa.edu/~nathan-b.../9instrume.pdf
Old 05-15-2008, 02:54 AM
HAVOC's Avatar
You can give these people a call, but it's probably expensive.
http://www.justdashes.com/Index.htm
Old 05-18-2008, 09:13 AM
ewong's Avatar
Thanks for the link!
I remember hearing about people who did this kind of work.
I wanted to make a "custom" sheet metal dash cover (aka a wider (left - right) and taller (to fit 2-5/8 guages) altimeter cubby that would entend the lenght of the OEM "hole" and then get it covered in foam and matching vinyl.
This looks like the place that can do that!
IMHO much nicer than "fiberglass" and safer too!
mskalmus
05-28-2017 07:51 AM
Road Bull
10-10-2015 04:55 PM
TURBOrunnerNM
07-22-2015 11:01 AM
msane99
07-11-2015 08:08 PM
coryc85
07-06-2015 04:07 AM
Quick Reply: Replacing or Reparing the Dashboard Top
