Rebuild won't start (yup, another one)
#41
Sorry for hijacking your thread, Wyofunrunner.
So, are you gonna pull the input shaft cover and replace the front bearing and seal? I've read enough threads describing when that goes bad it results in excessive movement that can destroy the input shaft seal and cause clutch damage.
How much crud was inside the bellhousing? Mine was horrible.
#42
It does bother me a little to buy expensive tools that I use "once." (I still have the vacuum pump (and gauges) I needed to replace my A/C compressor. But I have sold a lot of used-once tools on Craigslist.) Your choice.
Don't forget that the transmission may not de-couple from the engine effortlessly (yeah, it should, but that's not how it happens). So you'll have the jack holding the weight of the transmission (you'll think), and then push aft on the jack/transmission. We all hope it will just roll back a few inches, and you can gently lower it. But if you have to rassle it out, the whole thing gets a little more exciting.
So just be careful. HF wouldn't sell as many of these jacks as (I think) they do if people were having trouble with them. It's (mostly) well reviewed, if you put any stock in that.
And don't forget to use real jack-stands. Those cinder blocks are just decorative.
#43
My recently-deceased f-i-l left me some very nice 80's-era HF jack stands and hydraulic jack that I use often. At this point I don't climb underneath without them.
#44
I put the front of the truck on jack stands and the rear tires up on 6x6 blocks. Having the extra 6" of height is really nice. My engine and transmission do not like breaking apart or going back together. It's been an epic battle every time requiring tons of effort. By the time it's loose it was pretty easy to move around. Right now I'm trying to figure out what clutch I need. My truck was manufactured 7/1988 and seems to fall between years on Aisins spec chart...
#45
Also, I remember thinking I must be breaking the input shaft when I separated them the first time. Back together was easy once I realized I had to remove the lower half of the motor mounts...
#46
I assume by "blocks" you mean solid wood. Which is fine. Lots of people have been hurt when a "cinder block" just crushed.
If you want to be really high speed, consider these: https://www.harborfreight.com/solid-...set-63250.html Drive up on them, then put the other end on jacks stands. You can practical have a tea party underneath then. The trick is getting up onto them, as they want to slide forward as you drive onto them. I've laid 2x6's on the floor from the ramp to the back of the garage to keep them from sliding, but what works best is ... 4 wheel drive! If the front tires are driven (works with plain-ole front wheel drive too), they'll pull themselves up the ramp.
In theory you could back onto the ramps with a rear-wheel drive, but it's pretty unnerving just to drive forward onto them.
#48
It runs!!
I got the new clutch put in which went easily with help from a buddy. I buttoned everything else up just to check the function of the clutch and I bumped the starter and it immediately started and purred like a kitten. Turns out the aisin clutch disc splines were milled wrong and it didn't line up to the input and was binding on the engine. Lesson learned, always check the disc before installation. Woohoo!!
