Rear Tailgate Window problems on 1st gen 4Runners
Old 02-28-2009, 01:08 PM
4runnerCO's Avatar
87 4runner, just replaced the rear tailgate with a new one with a power window motor and window, all in working condition....cannot get the thing to roll up using the switch. Is there a fuse or something obvious im missing? A ground possibly. Also, running lights arent working and i cant figure those out either.
Old 02-28-2009, 01:41 PM
holskey's Avatar
hope this helps
is the rear wiper stitch on? if so turn it off and check. if its still not working try pulling your plug for the switch (window) and jump the connections to a ground. if that still doesn't work, check your relay. also try hot wiring the window motor.
the plug should look like this
x = test the ones with the x.
==x
Old 02-28-2009, 01:45 PM
ACSig's Avatar
Yes, there's a relay beside the tailgate on the driver's side. Here's a good writeup on how to fix it. You gotta learn how to use the search function on this website.
https://www.yotatech.com/forums/f128...runner-137310/
Old 02-28-2009, 02:46 PM
srozell's Avatar
There are a number of reasons why the rear window can stop working.
Check your wiper first to see that it's seated properly, and make sure you've plugged stuff in properly and not pinched any wires in the regulator in the process.
I've fixed a number of these rear window issues, and so far I haven't had to touch control units at all.
The motor is 12 volts, so just hook up a battery to it to prove to yourself you assembled it properly.
Old 02-28-2009, 04:19 PM
waskillywabbit's Avatar
Please learn to use our "search" forum as this is a common problem and you would have found many ideas and they would have all mentioned this link:
http://www.4crawler.com/4x4/CheapTri...arWindow.shtml
Old 03-03-2009, 05:17 PM
budguy88's Avatar
In need of help. Where is the rear power window relay on 89 4 runner?
Old 03-03-2009, 05:19 PM
Old 03-03-2009, 05:23 PM
abecedarian's Avatar
maybe this will help:
https://www.yotatech.com/search.php?searchid=5862748
if that doesn't, this might:
http://www.google.com/search?hl=en&q...h.com&aq=f&oq=
Old 03-03-2009, 05:48 PM
4runnerx3's Avatar
1. check and make sure you don't have the window lock switch on
2. top bolt switch, near rear tire on driver side, needs a bolt pushing down on it
3. tail gate needs to be closed, there is a latch switch (door has to be locked)
4. you can unplug the wiper wires in the corner where you disconnect the washer tube,
the window will work with this unhooked.
5. the relay is just pass the seat belt on the driver side
Old 03-03-2009, 06:26 PM
budguy88's Avatar
thanks
Just bought it and figured it would be an easy fix. didnt even have a relay just the connector lol
Old 03-03-2009, 06:28 PM
budguy88's Avatar
any suggestions on where to find a cheap one know the parts store wants 400 for one
Old 03-03-2009, 06:30 PM
Contact DeathCougar on Yotatech.
4x4-runner
02-26-2017 06:42 AM
Niameyrider
06-25-2015 05:50 AM
chbarnha
06-18-2015 10:23 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: Rear Tailgate Window problems on 1st gen 4Runners
