rear end vibration !!!!!!
hello
i got a 1990 toyota pick up 22re 2wd 4 banger
i got this rear end vibration that is driving me nuts! it did it before the new tires
ok this is what i have done already
*new front wheel berrings
*new tires
* wheel alighment
*back wheel berring are tight i think?do you check them like you do with the fronts?
*ujoints are tight no play
it seems to do it more on a turn on the highway and going downhill and up hill on the highway and it does it when i push in the clutch and coast too
*new tires
* wheel alighment
Rear axle bearings usually make a rumble sound when they are going out. May leak too.
Many of us check for sloppy u-joints but tight can be misleading. Make sure they are not siezed. You'll get a heck of a vibe.
is it vibrating all the time, when my u joint went bad mine only vibrated when i was accelerating or was giving the truck gas, didnt do when i was coasting
the1998sr5
15
07-14-2020 08:35 PM
FS[NorAtl]: 05+ tacoma leveling lift front MA
akaphilly
07-09-2015 02:18 PM
