Rear end sagging
Rear end sagging
Before you all bash me, i did search and i have read a ton of information, but it all seems misleading, or not my application.
I have a stock 93 4runner except for 3.4 swap. the rear end is sagging bad. i have seen Bilstein this and OME 891 or 906 that, blah blah, I need a solid answer. what to get to raise the rear end back level.
thanks for taking the time to answer
OME 2900 will raise the rear about 1and1/2 inch or so over unloaded stock hight.. I put these on my '95 Runner and I like them
OME 2901 will raise the rear about the same amount, but they are much stiffer, I'm glad I went with the 2900s'
OME fitment pdf.: http://www.arbusa.com/uploads/PDF/ac...ota4Runner.pdf
M O O G S P R I N GS!!!...in short. long answer, did my '92 complete justice. google it. i think i got mine on amazon
oh, and i pull a heavy trailer frequently. so, loaded...unloaded. dudn't matter. great ride. great ride height. and, a better price than everything else i'd looked at while still being a quality item
Moog CC255 coil spring set
Are these the ones you're talking about? I purchased these about a year ago but haven't gotten around to installing them yet. I did the same research as the OP and ended up focusing on these Moog springs as being a good fix.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Those are the ones I got and they worked great. Stiffened up the rear end a little bit. Overall very satisfied.
And they didn't raise the back end too much? That's sort of why I've held off on installing them, I didn't want to have them over compensate and raise the back end higher than the front.
Stiffening up the ride is a plus too.
those are the ones. no...they didn't raise the back end too much. there was some initial settling in after some heavy use, but i've had them on for maybe a year. still riding at stock height
if you're going to that, then you'll need longer brake lines and shocks. you're gonna do spacers on the front, too? if not, i don't see why you'd wanna install spacers in the rear. unless you want it looking all jacked up in the rear. that'll make it drive funny
