Rear end noise?
Rear end noise?
Bear with me guys i'm on my iPod....
I have a loud "click" in the rear end of my 4runner.
It only clicks while i'm in a forward gear and while I'm giving it gas, doesn't make noise in reverse or while coasting.
What could this be?! I thought u-joints first, but they have no play in them...I even greased them to see if it would make the click not so pronounced and it's still loud.
It sounds to me like it's coming from the center of the rear axle, which kinda sucks....... I'm going to drain the fluid in the rear end and check for metal shavings...just thought I would ask the Toyota junkies if they have any input
Thanks guys!!
Thanks guys!!
i'll definitely give those a shot..i've heard u-joints "clicking" before...but this is loud..almost like a thump.
at about $10 a pop i'll try u-joints LOL
Thanks Brian!
Thanks Brian!
If it moves, take off the tire and brake drum and see if you can move the axle. If you can move the tire then its probably the bearing. That will make the noise you described. Check your U-joints also as stated.
But if you have movement in the rear tire usually means the bearing is going bad.
Hope this helps
Larry
well guys...i replaced both u-joints in the rear driveline, took off down the road...and the noise is still there.
gets louder when you go faster.
it doesn't sound like it's at either end of the rear axle, sounds more like it's in the center....unfortunately.
i'm not sure how to go about fixing this as i've never experienced something of this nature.
i'm 90% sure that the truck has 4.56 gears..and that there are 2 4runners in the local junkyards with 4.56 rear ends...chances are one of them is good..one of them only have 10x,xxx miles on it.
what i would like to know is WHAT it is exactly?
P.S. this could be a chance to re-gear....i'm sure i could find a set of 4.88s in a yard somewhere (MIGHT be a set in the local yard..there was a couple of 4runners with some weird gear codes)
my highway RPM's at 65 is dead on at 3000 (in 5th gear) with my 285/75 Toyo's....and with 4.88's i'm thinkin it's going to be around like 3100-3200? which is going to give me a little more power....but worse gas mileage? i'm happy with my power right now but my mileage could be better lol so i think i'll just stick with 4.56's.
lol no it's not something that simple.
and it does it all the time now while driving...no matter if i'm goin in reverse or forward or coasting.
it's just louder while in a forward gear and giving it throttle
I'll suggest it one more time, then I'll quit. But it Is another spot that will make noise and cause a vibration, been there done that myself.
Take off your rear tires, remove the brake drums, grab the studs and see if you can move the axle. If they move, they are bad, its that simple. And they will cause a vibration.
I hope you find your problem
Larry
Larry
It's not a rumble peow, it clicks ONCE per revolution of something small like the driveshaft or an axle..guess I'll check a few more things this weekend...drain the gear oil too
i'm going to also replace the bearings and seals on both sides..
Currently on the lookout for a 4.56 diff, theres 2 in the junkyard one town over...but i'm not sure if they're good or not.
what should i look for when buying a junkyard diff? Besides the obvious like a chipped tooth on the ring or pinion...or not spinning smooth lol
