Rear Driveshaft Interchange
Old 11-17-2008, 07:09 PM
k1100lt's Avatar
Any-one know if there is something else out there that will fit my 1987 Turbo Automatic 4Runner? Would buy one if I could find one. Thanks, Glenn.
Old 11-17-2008, 08:23 PM
Staff
DeathCougar's Avatar
Try car-part.com there are about 25 drivelines listed
Old 11-17-2008, 08:31 PM
Matt16's Avatar
I think all 4RUnner and short bed trucks have the same DS.
Old 11-18-2008, 06:28 AM
91diesel's Avatar
What length do you need? I have a drive shaft out of a 93 diesel automatic 4runner and it is (if I recall correctly) 44" collapsed length. It only has about 60K on it. I'll never use it in my P/U so let me know if you're interested.
Old 11-18-2008, 01:47 PM
toyminator2000's Avatar
Not true. Auto transmissions have a completely different bolt pattern at the transfer case output. The 2nd Gen 4runners are about 2" longer than short bed pickups or 1st gen 4runners. The length difference may only be on auto trannys though.
Old 11-18-2008, 01:52 PM
881stGenRunner's Avatar
the difference is in the transmission. Auto transmissions are longer, thus having a shorter DS (~2") and the manuals are a little shorter, with a longer DS.
I get this from the measurements of the A340H auto found behind the 3.0 and the R150F found behind the 3.0 as well.
Try to measure the length of the tube end (not the slip end) and get a measurement that will not move depending on how much the yoke is pulled out.
gillesdetrail
08-03-2015 04:43 PM
kirkrunner
07-27-2015 07:59 PM
TDonkey
07-26-2015 10:14 AM
Iceman4193
07-15-2015 04:48 PM
icentropy
07-14-2015 10:23 AM
Quick Reply: Rear Driveshaft Interchange
